Is there any way we can create summary of work notes by using ServiceNow AI
mania
Is there any way we can create summary of work notes by using ServiceNow AI.
Can anyone please help on this, It will be helpfull.
Thanks!
Hi @Anurag Tripathi
can we use now assist , AI Summarization for custom tables ?
Yes i believe you can create a ui action to invoke the api to summarise. I haven't tried it though.
But as i mentioned before, Its a subscription based plugin so make sure your client/company has the necessary license.
Hi @mania ,
This is a paid plugin, should be purchased.
Hope this helps.
If my response turns helpful, mark it helpful and accept solution.
Ravi Chandra_K
Hello @mania
Depends on which Record you need summarisation.
If it for HR cases, then Now Assist for HRSD
If it is for CSM cases, then Now Assist for CSM
If it is for Incidents, Now assist for ITSM
Please mark the answer as helpful and correct if helped.
Kind Regards,
Ravi Chandra
