Issue with Catalog Client Script to set location
Kasia5
I have an issue with my Catalog Client Script related to set the location in Single Line Text variable based on user's location from another variable ('requested_for')
Currently it looks like:
    var affectedUser = g_form.getReference('requested_for', doAlert);
    function doAlert(affectedUser) {
        if (affectedUser) {
            g_form.setValue('requested_for_location', affectedUser.location);
and it was working fine my 'requested_for_location' field was a Reference field not a SIngle Line Text field.
When it is a Single Line Text filed then it gives me a sys_id value,,
Do you know how can I chnage the script to receive 'normal' string value in this Single Line Text field?
Thanks in advance for help!
Peter Bodelier
Hi @Kasia5
Try this:
        if (affectedUser) {
            g_form.setValue('requested_for_location', affectedUser.getDisplayValue('location'));
Help others to find a correct solution by marking the appropriate response as accepted solution and helpful.
Danish Bhairag2
Tera Sage
Hi @Kasia5 ,
Can u try using this
g_form.getDisplayBox('<field name>').value;
Please mark my answer helpful & accepted if it resolves your query.
Danish Bhairagdar
Ankur Bawiskar
@Kasia5
you cannot dot walk 2 level using getReference and also getDisplayValue() I doubt won't work in client side.
So you need to use GlideAjax only as the last option
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
Hi @Ankur Bawiskar,
I thought that as well, but it just works 😄
