Issues with Bidirectional Integration Using JIRA Spoke
Gulfam Shafee3
Hi Experts,
I am currently working on configuring bidirectional integration using the JIRA spoke and have encountered the following issues:
  1. I am unable to use the "Update Issue" action in JIRA Spoke, as the additional fields are grayed out.
  2. Whenever I update a comment in ServiceNow, it creates a duplicate entry in the worknotes.
Has anyone faced similar issues or have any suggestions on how to resolve these?
Thank you
9 REPLIES 9
Runjay Patel
Hi @Gulfam Shafee3 ,
Share the error log which you are getting.
Hi Runjay,
I have fixed the first issue. but still facing the second issue whenever i update the comment in servicenow. it created duplicate comment
Hi Gulfam,
How did you fix the 1st issue (Update Issue" action in JIRA Spoke, as the additional fields are greyed out). I am getting the same issue, but still trying to get a solution for this..
Please reply how it got fixed.
Balaji Prusty
Mathieu Lepoutr
Mega Guru
Hello @Gulfam Shafee3
For seamless bidirectional integration without these issues, you might consider using Exalate. It provides robust synchronization capabilities between Jira and ServiceNow with customizable workflows, reducing the risk of duplication or field limitations.
Mathieu Lepoutr
Mega Guru
Dear @Gulfam Shafee3
The issues you’re encountering are common challenges with prebuilt connectors. For more flexibility and control over bidirectional integration between Jira and ServiceNow, you might want to consider using Exalate. It allows customizable synchronization, avoiding limitations like grayed-out fields and duplicate entries.
If you’d like to troubleshoot further with the Jira Spoke, reviewing field permissions in Jira and configuring comment behavior in ServiceNow could help.
