04-01-2023 05:49 PM
Am trying to close off on the Configure sick conditions and it keeps failing for both Normal and Standard changes.
What I did:
- went to Change => risk conditions
- disabled the Insufficient lead time
- insert and stay on the Insufficient lead time
- on the new form: modified the name, made it active, set risk to high, adjusted to 7 days, and added a condition for normal.
- repeated for standard changes with standard changes, but 3 days and moderate.
- deleted all ... recreated new (no insert/stay), same outcome
- tested with change .. and the risk is actually set correctly with the message stating the challenge with insufficient lead time, but the simulator task fails 😞
- revalidated everything, but used a different path:
- opened a new normal change => edit risk conditions and rechecked everything
what am i doing wong?
moving onwards in the meantime, this one was confusing as it should have been simple and isn't 😞
- 7,520 Views
05-01-2023 12:46 PM
Make the third condition to be Model is Normal, and Model is Emergency for both Risk conditions respectively.
09-15-2023 08:16 AM
11-29-2023 02:24 PM
@carlosmoran41, per @doyin, all you need to do is adding the Model is Normal (or Standard) and that will work.
03-04-2025 05:52 AM
Saved my life!! I have been on this for almost and hour only to realize I had an extra space in the name!!!!
09-04-2024 05:58 PM
Hi all,
Just to share my steps and I got "Task validation successful":
1. Go into Risk Conditions
2. Unchecked "Active" for "Risk Conditions Insufficient lead time"
3. Added new risk condition Insufficient lead time - Normal Change with the next info:
4. Added new risk condition Insufficient lead time - Standard Change with the next info:
Hope this helps!
12-01-2024 10:16 AM
I didn't find the lead time column ,please anyone can help me to find this.
