JDBC Step Missing in Flow Action
Himesh Murthy
I'm not finding the JDBC Step to create a Custom Flow action in ServiceNow to integrate with Oracle Data base for data fetch. Can anyone help me with the plugin ID that should be installed to have this option enabled during the Flow action creation.
Himesh
Ankur Bawiskar
@Himesh Murthy
this one "com.glide.hub.action_step.jdbc"
Raghav Sharma24
Giga Patron
@Himesh Murthy Check if you can get this plugin installed from developer.service-now.com
else you will have to use your organization's dev instance to install this plugin.
