09-01-2025 05:24 AM
I've below 2 requirements -
1. When a RITM is moved by an 'agent' from 'Open' to 'Work In Progress', "Additional Comments" (instead of Work Notes) must be mandatory.
2. When a RITM is moved by an 'Assignment Group member (non-assignee)' from 'Open' to 'Work In Progress', both "Additional Comments" and "Work Notes" must be mandatory.
How I can achieve above 2 things.
09-08-2025 06:48 AM
Something like this but please enhance
I assume you are checking some agent role in your 1st point.
Script Include: It should be client callable
var RITMAgentGroupCheck = Class.create();
RITMAgentGroupCheck.prototype = Object.extendsObject(AbstractAjaxProcessor, {
isAgent: function() {
var userId = this.getParameter('sysparm_user_id');
// Check if user has 'agent' role
if (gs.getUser().hasRole('agent'))
return 'true';
return 'false';
isAssignmentGroupMemberNotAssignee: function() {
var ritmSysId = this.getParameter('sysparm_ritm_sysid');
var ritmGR = new GlideRecord('sc_req_item');
if (!ritmGR.get(ritmSysId))
return 'false';
var assignmentGroup = ritmGR.assignment_group.toString();
var assignee = ritmGR.assigned_to.toString();
// Check if user is in assignment group but not assigned_to user
var groupMemberGr = new GlideRecord('sys_user_grmember');
groupMemberGr.addQuery('group', assignmentGroup);
groupMemberGr.addQuery('user', userId);
groupMemberGr.query();
var isMember = groupMemberGr.hasNext();
var notAssigned = (userId != assignee);
if (isMember && notAssigned) {
return 'true';
return 'false';
onChange client script: State field
if (isLoading || newValue !== '2') // 2 = Work In Progress state, adjust as needed
var ga = new GlideAjax('RITMAgentGroupCheck');
ga.addParam('sysparm_name', 'isAgent');
ga.addParam('sysparm_user_id', g_user.userID);
ga.getXMLAnswer(function(agentResponse) {
if (agentResponse === 'true') {
// Agent moving RITM: Additional Comments mandatory only
g_form.setMandatory('additional_comments', true);
g_form.setMandatory('work_notes', false);
// Check assignment group member condition
var ga2 = new GlideAjax('RITMAgentGroupCheck');
ga2.addParam('sysparm_name', 'isAssignmentGroupMemberNotAssignee');
ga2.addParam('sysparm_user_id', g_user.userID);
ga2.addParam('sysparm_ritm_sysid', g_form.getUniqueValue());
ga2.getXMLAnswer(function(memberResponse) {
if (memberResponse === 'true') {
// Assignment group member (non-assignee): Both mandatory
g_form.setMandatory('work_notes', true);
// Otherwise, clear mandatory (optional)
g_form.setMandatory('additional_comments', false);
I believe I have answered your question and you can enhance it further based on your requirement and developer skills.
09-01-2025 09:49 PM
Hi @Ankur Bawiskar
Can you please help.
09-02-2025 12:12 AM
Hello @BKSharma
First, create a before update BR and check the current user to see if they are an agent or part of the group.
Second, within the BR, check the type. If it is an agent, mark Additional Comments as mandatory.
If they are a member of the assigned group, both fields will be mandatory.
To do this, either use a BR or a UI policy that checks the user.
With the UI policy, you can select the field and make it mandatory. With the BR, use this, for example:
g_form.setMandatory(‘comments’,true);
g_form.setMandatory(‘work_notes’,true);
09-02-2025 12:24 AM
you can easily achieve this using onChange client script + GlideAjax (to check who is moving the RITM)
where are you stuck and what did you start with?
09-02-2025 03:43 AM
Hi @Ankur Bawiskar , On Change Client Script part is ok. How I can check the who is moving the RITM and use that via Glide Ajax in the same Client Script?
