Metric definitions for Boolean fields
GM5
I'm currently noticing that Values for Boolean fields on a metric are being set as Date time values instead of "True" or "False" values, if you see the image the idea of that metric is to check Field value changes , is there any way to make this to be a True/False value instead of that Date time string?
This is the field:
GM5
I found the root cause, There are 2 Fields with the same label one was a Boolean and the other is date / time this caused confusion and we pick the wrong one, update on metric definition has been applied and we are getting the correct data, as I mentioned before there's a business rule that inserts the field display value into the metric instance "Value" field.
GM5
