miro enterpise integration with servicenow
09-09-2025 04:37 AM
Can anyone give me the step by step how to do miro enterpise integration with servicenow including the plugind required .
Thanks and Regards ,
Chandan
09-09-2025 05:03 AM
@Community Alums
Thanks for marking the post as helpful.
If my response helped to guide you or answer your query, please accept the solution.
Bhuvan
09-09-2025 10:19 PM
@Community Alums
Did you get a chance to review this as I believe the information provided should answer your question.
If my response helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
09-10-2025 11:35 PM
@Community Alums
Did you get a chance to review this ?
Bhuvan
09-11-2025 02:52 AM
Hi @Chandan,
For integrating Miro Enterprise with ServiceNow, you’ll need the Software Asset Management – SaaS License Management plugin (sn_sam_saas_int). While installing optional features, make sure to select the Miro Spoke checkbox so that the integration is enabled.
You can follow the step-by-step setup in the official ServiceNow documentation here:
https://www.servicenow.com/docs/bundle/zurich-it-asset-management/page/product/software-asset-manage...
https://www.servicenow.com/docs/bundle/zurich-integrate-applications/page/administer/integrationhub-...
This guide walks you through:
Creating the Miro Enterprise OAuth 2.0 application
Enabling SCIM and generating the API token
Setting up the Miro Enterprise and SCIM connections in Flow Designer
Creating the integration profile in SAM Pro
Hope this helps!
Thanks & Regards,
Muhammad Iftikhar
If my response helped, please mark it as the accepted solution so others can benefit as well.
09-15-2025 04:32 AM
