Multi row variable set is not showing if added within container variables
Ashish Ranjan G
I have a multi-row variable set and when I add it within a container, it is not showing up on the form. The MRVS shows up if I add it outside the container. Is it a known issue? Is there a workaround so that it shows up within the container?
Mahendra RC
Hello Ashish,
Please check once article if it helps to resolve your issue. You can see such issue due to incorrect usage of containers with Multi-Row Variable Sets.
Hello Ashish,
Just wanted to check with you, if the above response answered your question. If yes, then please do close this thread/question by marking the appropriate response as correct.
If you still need any further help or guidance on this then please update those on this question.
Hi Mahendra,
I looked at the KB however the issue was not related to improperly placed containers. In fact, MRVS does not show on the portal if added within containers. This is a known bug/behaviour. I used labels instead to fulfil the requirements. Thanks for your inputs though, appreciate that 🙂
