Multiple Choice variable bug in catalog/order guide
07-26-2026 07:25 AM
Hi guys! Can anyone help me with this issue that I'm facing, i was creating a order guide and creating a variable called Device Type, in which i gave 2 different choices but during the rule base i was able to see one. is it Australia patch bug or something because in earlier Zurich update patch there were no issue like this even I run the point scan it shows no error.
07-27-2026 08:20 AM
hi @igsumit007 ,
You're welcome! Glad the issue is resolved. 😊
If the replies helped you identify the solution, could you please mark the correct response as "Accept Solution"? It helps other community members who may run into the same issue in the future.
Also, if you found any of the responses useful, please consider clicking "Helpful" on those replies.
Thanks!
07-27-2026 08:32 AM
Hello @igsumit007
Glad we could help, please mark Helpful to the replies which helped you.
Raghavendra
