02-15-2026 09:57 AM
Hello, so my use case is to send a notification to the managers of the employees selected inside a multirow variable set , but when trying to dot walk it in flow designer it doesnt work.How can I achieve this ? any help will be very appreciated, and thank you in advance.
02-15-2026 08:40 PM - edited 02-15-2026 08:40 PM
you can iterate over the MRVS and then use "Send Email" flow action to send email
see this gif on how to do this in flow, also attached it in post
03-24-2026 09:13 AM
I hope you are doing well. Does my response helps you ?
If my response helps you then mark it as helpful and accept as solution. You can accept multiple responses as solution .
Aditya,
Technical Consultant
03-24-2026 10:26 AM
Thank you @Aditya_hublikar very much appreciate your help and insights on this
