Need Help identifying Duplicate records on custom table
Sunny14
Hello Team,
We have a custom Table X and for some reason the numbering has started creating duplication at the insert of the record. I need help identifying duplicate records. The number of records are huge 900K+ so Group by will take forever.
If we can printout the duplicate records via script, that would be good. After that we can work on those duplicates.
Thanks.
Ravi Peddineni
@Sunny14
Try this in the Background Scripts:
gs.info(getDuplicateValues(<table>, <field>));
function getDuplicateValues(table, field){
	var dupValues = [];
	var ga = new GlideAggregate(table);
	ga.addAggregate('COUNT', field);
	ga.addNotNullQuery(field);
	ga.groupBy(field);
	ga.addHaving('COUNT', '>', 1);
	ga.query();
	while (ga.next()) {
		dupValues.push(ga[field].toString());
	return dupValues;
****NOTE: It might take a lot of time to complete the query and might even get you session resources locked for this operation. So I strictly suggest you to run this in the possible lower instance where the criticality is low. ****
Reference: Get Duplicate Records from any table
Add this line before ga.query() function call:
ga.addEncodedQuery(“active=true”)
Thanks @Ravi Peddineni  I will try out.
