Need help with report on knowledge usage
08-19-2024 12:43 PM
Is there a way to create a report to calculate the knowledge utilization . Need help in finding article attached to incident.
08-19-2024 08:12 PM
Hi @Antony7
What exactly you need in report , please explain more , also put your question in KM forum to get experts advice.
08-19-2024 08:12 PM
08-19-2024 10:45 PM
Hi @Antony7 ,
What is it that you need to report on? In general you can utilize the tables kb_use and kb_feedback to report on knowledge utilization.
if my answer has helped with your question, please mark my answer as accepted solution and give a thumb up.
Best regards
Anders
08-21-2024 08:05 AM
HI @AndersBGS
Looking for Help on the KA attached to incidents /overall incidents closed by the specific group. Thanks you
Antony
