Need to enable hyperlink in Variable Under Catalog item
06-24-2026 04:13 AM
Hi Team,
I have enabled this msg by writing below script in Catalog UI policy. But I want to add hyperlink so that user can click that link and can be routed to the Onboarding form. Which module i can use to enable this
06-24-2026 04:26 AM
The message field is plain text. That's why your HTML isn't working.
You could put a URL field under it, containing the URL.
06-24-2026 04:55 AM - edited 06-24-2026 04:55 AM
Hi @vidyajadhav
You can try with Rich Text Label variable / URL type variable to show the link the message based on selected variable value.
A community member has achieved it using DOM - It is not recommended. Refer: https://www.servicenow.com/community/developer-forum/how-to-show-url-link-in-field-message-when-opti...
06-24-2026 05:02 AM
Hello @Tanushree Maiti ,
Unfortunately that gel method will not work in service portal ui , it will work on native ui(desktop) only 🙂
06-24-2026 05:10 AM
field messages don't support HTML Links etc
Couple of approaches
1) Either create URL type variable with default value and show/hide it based on your condition
OR
2) Create Rich Text Label variable and add link in it, then show/hide that variable based on your condition
06-24-2026 05:41 AM
Hi @vidyajadhav,
I was able to achieve this requirement using a Rich Text Label
Steps :
- Created a Rich Text Label variable in the Catalog Item.
- Added the informational message and hyperlink using HTML in the Rich Text editor (Source Code view).
- Styled the message using a <div> with background color, padding, and border to match the required UI.
- Used a Catalog UI Policy to show/hide the Rich Text Label based on the selected value in the Role/Option variable.
<div style="background: #d9edf7; border: 1px solid #bce8f1; padding: 10px; border-radius: 4px;">Choose the appropriate Project Business Role. <br><br>If you are not sure, please check with the Project Lead. <br><br>Raise a separate request to complete the Business Role onboarding <a href="/sp?id=sc_cat_item" target="_blank" rel="noopener noreferrer nofollow"> here </a> if you cannot find your team's business role on the list.</div>
After testing in both Native UI and Service Portal, the hyperlink is displayed correctly and is clickable.
