Need to increase precision of floating point fields to 15 digits after decimal for latitude and long
pdurgapavan
I have two fields on the Location table called latitude and Longitude- both are floating point number fields.
By default the system allows up to 7 digits after the decimal point. if we are giving more than 7 digits value is rounding off.
But I would need to store the coordinated with 15 digits after the decimal point, and also need 4 digits before the decimal point. (including the '+', '-' sign)
Example latitude : -90.897845651232145
longitude: -180.321232126545987.
How can I modify these fields to store such high-precision floating values without rounding or truncation?
Could anyone please help me to achieve.
And one more thing I would like to tell you on the latitude field I turned on to advance view and on the attributes I gave scale=15 and maximum length I updated to 50. now it's taking 13 digits after decimal but if we are giving more than 13 digits then the value is truncating.
pdurgapavan_0-1752602491259.pngpdurgapavan_1-1752602540287.pngpdurgapavan_2-1752602591638.png
could anyone help me with the logic.
@Ankur Bawiskar
@Dr Atul - LNG
@J Siva
@glideFather
@Chaitanya ILCR
@sandeepdutt
Di Zhang
I think this is work as designed. ServiceNow normally only support 13 digits in decimal.
