Not able to compare date/time field
I have to field start date and end date. I want to put validation so that end date should not be before start date. I am able to achieve this but it is getting failed in one case.
case:
Start date :31/10/2023
End date: 2/11/2023
In above case, code consider end date as less than start date.
Client script
var ga = new GlideAjax('DateTimeFunc');
ga.addParam('sysparm_name', 'compareDates');
ga.addParam('start_date', g_form.getValue('date_time_from'));
ga.addParam('end_date', g_form.getValue('date_time_to'));
ga.getXML(getEndDate);
function getEndDate(response) {
if (answer=='true')
alert("End date should be after start date");
  //g_form.clearValue('date_time_to');
Script includes
compareDates: function() {
var chg_start_date = this.getParameter('start_date');
var chg_end_date = this.getParameter('end_date');
if (chg_start_date > chg_end_date)
return true;
return false;
@Community Alums
Please add one more condition to the UI policy.
End date is not empty.
Please mark my answer as correct based on Impact
Ankur Bawiskar
@Community Alums
you will require 2 onChange 1 for start and 1 for end
Either create 2 onChange or 1 onSubmit to validate
I am sharing onSubmit, you can use similar in onChange
function onSubmit() {
	g_form.hideErrorBox('start_date');
	g_form.hideErrorBox('end_date');
	if(g_form.getValue('start_date') != '' && g_form.getValue('end_date')){
		var start = new Date(g_form.getValue('start_date')).getTime();
		var end = new Date(g_form.getValue('end_date')).getTime();
		if(end < start){
			var message = 'Please give valid start and end dates';
			g_form.showErrorBox('start_date', message);
			g_form.showErrorBox('end_date', message);
			return false;
Hi @Ankur Bawiskar ,
I tried the given code, but its not working, when I alert the dates, It shows me Invalid date. Could you please guide me on this.
Thanks!!
@Community Alums
please share your latest script
Below is my latest script:
               alert(start+""+end);    //this gives me invalid date
		if(end < start){
			alert("true");
			return false;
