02-08-2024 10:33 AM
I was working on an article in SNOW (KBA00322077), and I had a sentence between to numbered items. In the image below, when I tried to use the number formatting, it defaulted to 1. Is there a way to change the number value? I manually typed the “3.” and aligned the sentence with the rest of the numbered items.
Thanks!!
Service Operations Workspace
02-08-2024 10:27 PM - edited 02-08-2024 10:27 PM
Hi @kimdarcoo
Either you can use another bullet list for the sentence like below
or you can go to the source code( by clicking on <> icon ) edit it like adding <p> tag between that two numbered items
like below
then it will look like this
Hope it helps
02-09-2024 03:21 AM
Its not SNOW, ist SN or ServiceNow.
02-09-2024 05:42 AM
You know your response is not useful. Thanks.
