04-12-2022 06:33 AM
hi
My requirment is i want to display a field and it should be mandatory, i want to display a field when defects is selected in a list collector variable, but iam getting the field also when i select the other variable in the list collector? i have written on change client script but it is displaying the new field for two values where as i want to display value only when defects is selected?
kindly look into screenshots.
the new field should not be visible while selecting incident but what happening is that if i select defects and remove defects and select incident the new field is not hiding
Change Management
04-12-2022 08:32 AM
04-12-2022 08:32 AM
Hey Sai,
Did the solution worked for you?
Cheers..!
Tushar
04-12-2022 08:50 AM
Yes. thanks tushar and chris
04-12-2022 09:05 AM
Glad to hear!
Happy Learning:)
Tushar
