On Incident, Assignment group is not changing to other, when Application is Blackline. What to do?
AbdurRahmanSnow
Good afternoon.
I have an Incident ticket, where the Assignment group is not getting changed to any other groups, when Application is Blackline. What is the reason behind this?
Assignment groups are coming, but when saved, it is going back to the same Assignment group. Please help.
2 ACCEPTED SOLUTIONS
Hi @AbdurRahmanSnow
In the filter conditions change the condition to application changes to Blackline and test it once by putting log into it.
Make sure that your BR will be triggered only when Incident's Application changes to Blackline.
Kindly mark my answer as helpful and accept solution if it helped you in anyway. This will help me be recognized for the efforts and also move this question to solved bucket.
Prathamesh
@AbdurRahmanSnow
currently your BR simply checks Application and sets Group
You can use script to populate Group based on Application selected
What do you mean by not allowing you to change the group?
Check any reference qualifier is added on Assignment group field via dictionary override
Dr Atul - LNG
Hi @AbdurRahmanSnow
There is OOTB BR update Assignment group based in CI/ SO please check is that causing issue.
Ankur Bawiskar
@AbdurRahmanSnow
how is assignment group getting populated?
are you having any onChange of Application which brings and populates Group?
share that script
Hi @Ankur Bawiskar
I have found a Business rule that is not allowing to change the Assignment group, when Application is Blackline. It should allow to change it to other groups.
What changes can we do for this?
@AbdurRahmanSnow
