onChange script error: RangeError: Maximum call stack size exceeded function () { [native code] }
pramodkumar
I have 2 checkboxes on a form and there are 2 onchange client scripts on each of them. Whenever I tried to make update it, I am getting below error
below is the script on checkbox1:
var ch = g_form.getValue('checkbox2');
    if(ch == 'true'){
        g_form.clearValue('checkbox1');
        alert("Select only one");
below is the script on checkbox2
var ch = g_form.getValue('checkbox1');
    if(ch == 'true'){
        g_form.clearValue('checkbox2');
@pramodkumar
I would suggest you start from your side so that you will learn.
@pramodkumar Did you try the solution suggested by me?
Sandeep Rajput
@pramodkumar Inside the onChange script of Checkbox 1, you are checking if the checkbox 2 is already checked and then clearing the value of checkbox1 which is causing a recursive function call for the onChange client script for checkbox 1. You are doing the same thing for checkbox 2 as well and both of these scripts are causing infinite loop.
I recommend addressing this requirement via a UI Policy and its script field as follows.
1. UI Policy on Checkbox 1
Screenshot 2024-03-28 at 9.54.43 AM.pngScreenshot 2024-03-28 at 9.54.46 AM.png
2. UI Policy on Checkbox 2.
Screenshot 2024-03-28 at 9.55.23 AM.pngScreenshot 2024-03-28 at 9.55.37 AM.png
Do not forget to deactivate your onChange client scripts on checkbox 1 and checkbox2 before applying this solution.
Hope this helps.
