Order guide using record producer
wbrice
Kilo Expert
Can someone point me in the right direction of how to gt a record producrer attached to a order guide. I've been searching and I don't think it's possible, but I wanted to see if anyone else has done this before.
Thanks for any and all help guys
Will
chadlockwood
William,
I just fixed this last week. You need to go to sys_properties.list, find the property glide.sc.item.order_guide_exclusion and remove sc_cat_item_produce from the Value list. Then, record producers will appear in the slushbucket for items you can add to your order guide.
chadlockwood
William,
Thanks, have you hear why they hid this in the first place? Is it introducing a vulnerability somewhere??
I asked SNOW and they said it couldn't be done..... surprise it can. I know they can't tell us yes you can, and this is how you do it, but don't do it because xyz. They just say no.
I have personally done this, but ran into issues, though I cannot recall why exactly - been a few years.   I seem to remember something with the variables on the record producer not showing up or being usable.   But this was on Aspen or Berlin so maybe that was addressed since then.
Hi Michael,
Is this still an issue and we should avoid using record producer on order guide?
Sonali
