Populate values based on selection of options in list collector field
suuriya
I have a requirement, in catalog form there are 3 fields namely Select site name, Select Print groups and Printers included in group (FYI select print groups is dependent on select site name field) If any value is selected in select Print groups field, then printers' details need to populate in printers included in group field.
Select Print groups field is a list collector so multiple options can be selected...For example if i select "print group - tampa" in Select Print groups field then TAM-DV, TAM- SAT, Barcode these values need to be populate in Printers included in group field....likewiswe if i select more than 1 value in list collector field then respective printers details need to be populate in the field
Example
in this case 2 values selected so AM-DV, TAM- SAT, Barcode and zebra tear, zebra 00 zebra 10 these values need to be populate in printers included in group field
There are multiple options present in select print groups so based on selecting each option a set of printer details need to populate in printers field....I have list of printer details related to each group in excel.
How can we achieve this.....please help me with entire onchange script.
Thanks in advance
13 REPLIES 13
Hi @suuriya replace the below bolded line. Make sure the field name from select_print_groups table is correct in script include .
getApplication : function(){
var CI = [];
var sysId = this.getParameter('sysparm_sys_id'); // sysid of list collector values from client script
var almAssetGr = new GlideRecord("select_print_groups"); // glide the table which your using as list collector where the values stored
almAssetGr.addQuery('sys_id', "IN", sysId);
almAssetGr.query();
while (almAssetGr.next()) {
CI.push(almAssetGr.getValue('u_printer')); // here you need to get the printer value
return CI.join();
Harish
Hi @Harish KM ,
I replace the line but it is showing as null
var Printer = Class.create();
Printer.prototype = Object.extendsObject(AbstractAjaxProcessor, {
        var CI = [];
        almAssetGr.query();
         CI.push(almAssetGr.getValue('u_printer')); // pass the field name where you want to populate values on other field
            return CI.join();
    type: 'Printer'
Hi @suuriya
Can you put logs here and check what value your getting? The below sys id should match the record in your printer table which you select on list collector variable and then in this table you need to get the value of the field which you want to auto populate
gs.info("sysID==>"+sysId);
Harish
Hi @Harish KM ,
I add the infor part
        var CI = [];
        almAssetGr.query();
            return CI.join();
    type: 'Printer'
and i can see sysid in logs but value is not getting populate and i also see error and warning in logs
Hi @suuriya your table name is wrong here check bold line below
var CI = [];
replace to
var almAssetGr = new GlideRecord("u_kallik_sites_codes_and_access_groups"); // put correct table name
almAssetGr.query();
return CI.join();
type: 'Printer'
Harish
