Preview Record of a Reference Field Allows Users to Edit Their Records Through Catalog Form
07-10-2026 12:34 PM
Hi everyone!
I need help figuring out how to fix this issue.
We just discovered that users (both ITIL and non-ITIL) can update their own records by clicking the "i" icon beside a field in the catalog form. This field is a reference field that points to the sys_user table.
Our requirements are:
1. Non-ITIL users should not be able to update their records. All fields must be read-only.
2. ITIL users should only be able to update their mobile phone number. All other fields must be read-only.
How can we achieve this? I appreciate any suggestions or guidance. Thanks in advance!
07-26-2026 08:56 PM
Hi @Irene M ,
Hi @Irene,
Since the reference icon opens the sys_user record, access is controlled by ACLs, not by the catalog item itself.
A good approach would be:
Create a table-level Write ACL on sys_user that allows the appropriate ITIL users to update user records.
Create a field-level Write ACL on sys_user.mobile_phone that allows those ITIL users to edit only the Mobile Phone field.
Create a field-level Write ACL on sys_user.* that denies write access to all other fields.
For non-ITIL users, simply ensure they do not have write access to the sys_user table, so all fields remain read-only.
You'll need the security_admin role to create or modify ACLs. If you don't have it, you'll need to work with your ServiceNow administrator.
I hope this helps! If you have any questions or run into any issues implementing it, feel free to ask.
07-27-2026 01:04 AM
Hi @ajmalmuhamm thanks for responding. Something we forgot to consider is that we have an automation from ActiveDirectory that writes user information in our sys_user table. When I did this, it blocks ActiveDirectory leaving newly created user with empty information such as Name, title, email, etc. basically all the fields that we deny write access.
