Print count and incident numbers for incident with top 3 priorities
Asmita7
Hello friends,
I have a query :
E.g.
Priority 1 - has 50 inc
Priority 3 - has 45 inc
Priority 5 - has 35 inc
Priority 4 - has 5 inc
Priority 2 - has 1 inc
Than i have to print top 3 priority with incident number.
Which approach is better
Ankur Bawiskar
@Asmita7
where are you planning to write this?
We don't know your exact requirement and the business use-case?
Thank you @Ankur Bawiskar
It will be used in a Scheduled Job or Fix Script .... we need to process these incidents further after filtering.
Please help.
Thank you
@Asmita7
so if you are using that in scheduled job then you need to know which query should be applied to perform further processing
the question you asked simply says you want to print
Dr Atul - LNG
Hi @Asmita7
The report will be like this
or try like this
// Create a GlideRecord object for the incident table
// Define an array to hold the top 3 priorities
var topPriorities = [];
// Query the incident table to get the top 3 priorities
gr.orderBy('priority');
gr.setLimit(3);
while (gr.next()) {
// Push the priority into the array if it's not already there
if (topPriorities.indexOf(gr.priority.toString()) === -1) {
topPriorities.push(gr.priority.toString());
// Now, we will count incidents for each of the top priorities
var priorityCounts = {};
// Initialize counts for each top priority
for (var i = 0; i < topPriorities.length; i++) {
priorityCounts[topPriorities[i]] = 0;
// Query incidents again to count them by priority
var countGr = new GlideRecord('incident');
countGr.addQuery('priority', 'IN', topPriorities);
countGr.query();
while (countGr.next()) {
var priority = countGr.priority.toString();
priorityCounts[priority]++;
// Print the results
for (var priority in priorityCounts) {
gs.info('Priority: ' + priority + ', Count: ' + priorityCounts[priority]);
