Problem Form: HTML Fields Read-Only and Fix Button Not Working
Lauren Bell
All HTML-type fields in the Problem form are appearing as read-only. This includes fields such as Workaround, Cause Notes, and Fix Notes.
Additionally, when we click the Fix button on the Problem form, the related popup window does not open.
See the image below :
abbasshaik4
Tera Sage
Hello @Lauren Bell,
Please refer to the link below:
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0960097
If it is helpful, please click the thumbs-up button and accept the correct solution. By referring to this solution in the future, it will be helpful to others.
Thanks & Regards,
Abbas Shaik
Hi @abbasshaik4,
The field is visible, but it is read-only. I’ve already tried the solution you provided, but it didn’t work.
