Query business rule help
‎12-14-2025 11:41 PM
I am trying to run a query business rule to check on multiple conditions which works one way or the other.
If I run the Ismemberof condition or the qc and/or condition within query BR separately it works. But when I try to combine both to check, only the qc condition works and does not include the ismemberof in encoded query.
‎12-15-2025 02:19 AM
so query is correct but for your persona it's not getting applied properly?
can you give your complete business requirement here
‎12-15-2025 04:44 AM
Requirement is to restrict access to table records.
When logged in user is assigned person of ticket, then show those tickets.
When logged in user is opened by person of ticket, then show those tickets.
When logged in user is part of certain group, then show tickets where parent ticket, service owner of ticket is abc for example.
it seems to work when I try to push like below.
‎12-15-2025 05:03 AM
‎12-15-2025 05:14 AM
Instead of using addOr condition like below
var qc = current.addQuery("assigned_to", current.getValue("sys_id")); // comparison with user sys_id
qc.addOrCondition("opened_by", current.getValue("sys_id"));
if (qc.hasCondition()) {
var fallbackQuery = "assigned_to=" + current.getValue("sys_id") + "^ORopened_by=" + current.getValue("sys_id");
encodedQueryParts.push(fallbackQuery);
}Tried to have it separately, it seems to work.
‎12-15-2025 01:09 AM
Hi @imran rasheed ,
Can you please try with below script
var encodedQueries = [];
var userId = gs.getUserID();
if (gs.getUser().isMemberOf("ABC")) {
encodedQueries.push("parent.u_service_owner=2122342312");
if (gs.getUser().isMemberOf("DEF")) {
encodedQueries.push("parent.u_service_owner=232323432");
// Assignment fallback logic
"assigned_to=" + userId + "^ORopened_by=" + userId
gs.log("encodedQueries = " + encodedQueries);
// Combine with OR
if (encodedQueries.length > 0) {
gs.log("Inside IF = " + encodedQueries.length);
var combinedQuery = encodedQueries.join("^OR");
gs.log("combinedQuery = " + combinedQuery);
gs.addInfoMessage("Complete query: " + combinedQuery);
current.addEncodedQuery(combinedQuery);
Also check the values coming in the log.
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
