"Operation against file 'problem' was aborted by Business Rule 'Transform synchronously^<sys_id>'. Business Rule Stack:Transform synchronously"
‎04-27-2020 02:23 AM
Im trying to update the state of the problem record through an import set API transform script. I get an error
How to resolve this?
Problem Management
‎04-28-2020 10:26 PM
Did you try setting to some other state?
‎04-29-2020 12:41 AM
If you try target.state = '107';
Ashutosh
‎04-29-2020 04:13 AM
I tried the below,
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
try {
gs.info("Target record: "+ target.sys_id);
var parser = new global.JSON();
var parsed = parser.decode(source.u_event_details);
gs.info("Sys_id" + source.u_snow_id);
if (parsed && Object.keys(parsed).length > 0) {
if (parsed.workflowIndicator == 'Problem') {
var state = parsed.issueDetails["Issue Status"];
if (state === 'ignored')
target.close_notes += 'Event ignored in Source system';
else if (state === 'resolved')
target.state = '106';
target.close_notes += 'Event resolved in Source system';
target.setWorkflow(false);
catch(ex) {
var message = ex.getMessage();
})(source, map, log, target);
Now again I have started getting the same error 'Operation against file 'problem' was aborted by Business Rule 'Transform synchronously^<sys_id>'. Business Rule Stack:Trasnform synchronously"
in spite of using setWorkflow(false)
‎04-29-2020 06:08 AM
HI,
If you are doing it using Before script then you dont need target.setWorkflow(false); as you already set the run BR as false on transform map.
Ashutosh
‎04-29-2020 04:24 PM
Agreed. Then I don't understand how the business rule is still getting called.
