05-13-2020 02:08 AM
I am using the below script for onSubmit. The If condition gets passed through and am getting the error message "This page is restricted to employees only." But, the ticket gets submitted. Return false is not working.
function onSubmit() {
var user = g_form.getReference('requested_for', setUserType);
function setUserType(user){
//var userType = user.u_user_type;
var service = g_form.getValue('service_type');
var phone = g_form.getValue('phone_type');
if (userType != 'Corning Employee' && service == 'new' && phone == 'personal_device'){
g_form.addErrorMessage("This page is restricted to employees only.");
return false;
Service Catalog
05-13-2020 02:17 AM
Hi Imran,
getReference() with callback is asynchronous I think it is submitting the form by the time your callback method triggers;
If this doesn't work move your validation as onchange client script on service type and phone type variable/field
To confirm this add alerts
alert('CallBack method called');
alert('Stop form');
return false;
05-13-2020 02:22 AM
Hi Ankur.. Thanks.. Both the alerts are getting triggered. getReference() with callback might be the case.
What could be the solution?
05-13-2020 02:27 AM
it wont work. because asynchronous call is happening .
you have to use here onChange client script , if you are on table then use before business rule using setAbortAction(true)
05-13-2020 02:40 AM
Hi Imran,
As suggested by
1) if this is for record producer then before insert BR on the target table of record producer
2) if this is for catalog then onchange client script
05-13-2020 02:18 AM
I think your case is similar to below link...
Please , check it is worth noting what has been said in below link regarding getReference.
Mark my ANSWER as CORRECt and HELPFUL if it works
