Regarind MRVS value read and set it into a multiline text
1_DipikaD
 Hi all, I have a requirement of get the MRVS values and set it into a Multiline text which is present inside a SingleRow Variable set from a catalog item but when it came to RITM and sc_task the vlaue is not visible accurately as expected.
i have attached the picture i have to set memebr of the distribution list  to the ITS CE-API API variable which is a multiline text set inside a single row variable set. i have write a OnSubmit() client script.but it is not giving accurate output it is show '/'  and the sys-id of the member i have tried
function onSubmit() {
    // Retrieve the value of the 'members_of_the_distribution_list' field
    var mvrsValue = g_form.getValue("members_of_the_distribution_list");
    g_form.setValue("api_variable", JSON.stringify(mvrsValue));
but it is not working can any one suggest how to achieve it through workflow
@Ankur Bawiskar
current.variables.variable_name ='yes' ; // when its not part of variable set
current.variable_pool.variable_name = 'yes'; //when part of variable set
