03-27-2024 11:26 AM
Kindly help me to understand below:
1. If risk is accepted for a problem record should the problem ticket marked as resolved as there is no permanent fix available to the issue ?
2. If there is an incident due to same issue where risk is accepted and problem ticket is closed, should this incident be linked with old and closed problem ticket ?
3. In such cases can we directly link incident with the known error article as problem is already closed and risk is accepted with no fix applied ?
03-27-2024 11:30 AM
Hi @SaswatiC
Atul: Not automatic, but manually. Also the risk must be added in RAID log. Try to find out the work around and accept risk. Without workaround risk acceptance is too risky.
Atul: again, as per process, Yes you can link with prb and close the problem record.
Atul: Yes, that is a good practice.
03-27-2024 11:30 AM
Hi @SaswatiC
03-27-2024 11:34 AM
Thank you Atul for your quick help to get my queries answered.
