Retroactive start
sandie
Kilo Expert
What is meant by Retroactive Start = Original Date in SLA. How does this work ??
9 REPLIES 9
Midhun1
Giga Guru
When a task record changes, typically a new SLA may be attached, with a new set of timing information. This is useful if you are re-assigning an incident to another group and want to attach a new SLA record with new timing information.
However, you may want to retain the task's time information in specific situations. For example, an incident is raised with a priority of 3 - Moderate and the priority changes to 1 - Critical after 3 hours. A priority 1 SLA is attached to the incident at that time. You can use retroactive start to ensure this SLA timing is adjusted retroactively to count from when the incident was first created, rather than from when the incident's priority changed. This reflects the actual time the user contacted you.
Note: When retroactive start is enabled, it may result in task SLAs being breached as soon they attach, which will trigger multiple notifications. To prevent the workflow from being processed for these breached SLAs, set the com.snc.sla.workflow.run_for_breached property to false.
To prevent immediate breaches and notifications when retroactive start is enabled for SLA definitions, enable the retroactive pause property to apply pause times to the new SLA.
Thank you so much for all your responses,
I am actually looking for an answer for - Retroactive Start = Original Date not Retroactive Start = Create Date
Like for Retroactive Start = Create , SLA is calculated based on the create date of the task. How does it work for Retroactive Start = Original Date
I believe this is the customized one in the instance I checked. Kindly ignore !!
Talya
Hi @Midhun1 , We have P1 to P4 Resolution SLAs. I have set the Retroactive start to Created and Retroactive Pause is enabled.
1. When incident is created with P3 , P3 Resolution SLA is attached, say at time X
2. After 15 minutes if I change the priority to P1 then P3 is paused and P1 Resolution SLA is started with Start time as X+15 and started with 0 seconds.
Please tell me what am I missing here?
What value should I set Retroactive start to? So that it considers the ticket created time.
Midhun1
Giga Guru
