RITM is not routing to assignment group properly
priyanka0709
When we raise RITM from particular catalog item then it directly assigns to assignment group as expected but some of them are not directly assign to assignment group when its created. we need to assign it to particular assignment group manually.
shyamkumar VK
Mega Patron
@priyanka0709 ,How your handling this Auto Assignment?? Check if there are conditions specified to Auto assign the Request , Validate them against your failures (In case conditions might not be passed)
Shyamkumar
Please mark this as helpful and accept as a solution if this resolves your Ask.
Shyamkumar
Sumanth16
Mega Patron
Hi @priyanka0709 ,
Please verify your workflow (or) flow script and try to print values in system logs for debugging purpose in lower instances only.
If I could help you with your Query then, please hit the Thumb Icon and mark it as Correct !!
Thanks & Regards,
Sumanth Meda
Dnyaneshwaree
Hello @priyanka0709,
If you have setting the assignment group from workflow/flow/script then you need to check for the conditions if any. And If there is no any conditions or logic present related to the visibility of assignment group in it, please check that the particular catalog items are available only for one group that is other than the required assignment group of RITM. Also, check for the ACLs if any.
Thank You!!
Please accept my solution if it works for you and thumps up to mark it as helpful.
Thank you!!
Dnyaneshwaree Satpute
