Script error
rahul122
I am facing a script error issue in the change form when the change is approved under the status field i have checked the client scripts but i could find any thing related to status change ,how can i solve this please help
12 REPLIES 12
Himanshu Verma
Hi there,
Please check UI Policies and client script, check with the error.
Yes i have checked that
swathisarang98
Hi @rahul122 ,
Could you put filter as " script contain status" in client script, give type onchange and table change_request and check whether any client script is present if so please share the code
Please mark this comment as Correct Answer/Helpful if it helped you.
Swathi Sarang
I have checked with that filter but no luck
ChrisBurks
I'm not sure if this will help but what I see from the screenshot is that a change was made (indicated by the blue icons) on the Status field. That could be an onchange client script (is the client script doing a GlideAjax call) or a flow could be tied to Change Requests.
