Script to check if user is part of existing group
Revathi12
Hi Team,
I have a requirement where I have 2 fields existing groups and add new group. In existing group I'm populating the groups which are already mapped to user. Whereas in the field Add New I need to populate the groups which are not mapped for the user and he should select only those groups.
Note both are of list collector variable types. Below is the script
Script Include :-
getNewGroups: function() {
        var groups1 = [];
        var groupName = this.getParameter('sysparm_group_name');
        var gr1 = new GlideRecord('sys_user_grmember');
        gr1.addQuery('group.name', groupName);
        gr1.addQuery('user',gs.getUserID());
        gr1.query();
       while (gr1.next()) {
             groups1.push(gr1.getDisplayValue('group.name'));
        return groups1.toString();
Client Script :-
alert ("tst1"+newValue);
var ga = new GlideAjax('POC_RN');
ga.addParam('sysparm_name', 'getNewGroups');
ga.addParam('sysparm_group_name',newValue);
ga.getXML(getResults);
function getResults(response) {
    if(answer!=''){
    g_form.addInfoMessage("group already exists");
   g_form.clearValue('add_new');
   else {
    g_form.setValue('add_new', newValue);
20 REPLIES 20
PFA
Your groups field, I hope is also list collector field referring to sys_user_group table.
It should work just fine
Vishal Birajdar
Hello @Revathi12
Can you try like below :
Step 1 : Create Script include (Do not make client callable);
/*Get Groups which user is member of*/
 isMemeberOfGroups: function() {
        var userId = gs.getUserID();
        var groups = [];
        var grMem = new GlideRecord('sys_user_grmember');
        grMem.addQuery('user=' + userId);
        grMem.query();
        while (grMem.next()) {
            groups.push(grMem.getValue('group'));
        return 'sys_idIN' + groups.toString();
/*Get Groups which user is not member of*/
isNotMemeberOfGroups: function() {
        var groups = [];
        var notPartOfGroups = [];
        grMem.query();
        var grGroup = new GlideRecord('sys_user_group');
        grGroup.addQuery('sys_idNOT IN' + groups.toString());
        grGroup.query();
        while (grGroup.next()) {
            notPartOfGroups.push(grGroup.getUniqueValue());
		return 'sys_idIN' + notPartOfGroups.toString();
Step 2 : Add reference qualifier in Variable 'Existing groups'
This will return the list of existing groups
javascript: new CheckGroupMembership().isMemeberOfGroups();
//Please see the screenshot for format
Step 3 : Add below reference qualifier in variable "New Groups"
javascript: new CheckGroupMembership().isNotMemeberOfGroups();
This will return the groups which user is not part of
Output :
For me Admin is only part of two groups
and not part of below groups
Hi @Vishal
Thanks for the response. It is not working for existing groups, whatever the user I select it is showing the same groups.
Hi @Revathi12
Have you updated the same script include which you have previously used...??
Can you try to create new script include and then check....!!
