Servicenow Salesforce Integration Spoke - Update case
Bhavna gupta
I am trying to integrate Servicenow with Salesforce using Salesforce Spoke. I have setup the Oauth and it is generating OAuth token successfully.
But in the flow designer, when I try to use the Salesforce spoke action - Update record, I am not able to get the additional field values.
+Add field value : this button is disabled.
I added the field to be updated in script.
But when I test the flow, it is giving me this error for Action - Update record:
Expected argument of type object, but instead had type undefined
Please help!
Keerthi Kongari
@Dylan Mann1 I am facing the same issue with Create Case action, could you please share the resolution for this issue?
Did you find any resolution for this issue?
I was facing the same error for Create Case Spoke.
I checked the connection & repaired the application.
This helped!
