showFieldMessage & ErrorBox msg nor working
Naveen87
Hey Guys,
Im trying put an error or info message under the field. But it's not reflecting.
g_form.showFieldMsg("start_date","Selected Date is in past, Select a valid date","info",true);
suggest me something here
Was that not happening before?
Actually, you know what...hmm...try clearing the field first THEN do your field message.
g_form.setValue('start_date', ''); // Setting the variable as empty
g_form.showFieldMsg('start_date', "Test 123", 'error');
17 REPLIES 17
Can you add an alert before the field message to confirm that the code is getting executed.
also, Can you confirm you are using this on start_date field and not work_start
If the showMsg field replaced by alert . It's working.
Yes, it written on start_date.
Mark Roethof
Hi there,
Can you share how you are using this? In a (Catalog) Client Script? onChange perhaps?
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Hi Mark,
Find the script below,
var change = g_form.getValue('u_change_type');
//if(newValue != '')
if(newValue == 'major'||'minor');
var ga = new GlideAjax('ConfirmDate');
ga.addParam('sysparm_name', 'chkCurrDate');
ga.addParam('sysparm_date',g_form.getValue('start_date'));
ga.getXML(NewParse);
function NewParse(response){
if(answer == 'false'){
g_form.showFieldMsg("start_date","Selected Date is in past, Select a valid date","error",true);
g_form.setValue('end_date','');// Setting the variable as empty
Allen Andreas
Unfortunately, more information is needed. You've mentioned the "alert is working fine"...where did you place that alert? It's not in your code included below?
You've provided the client script, now I'm assuming we'll need the script include...?
So we're getting it, piece by piece. Please provide more information about what alert statements you've used and where.
We need to verify what is coming back from your script include to see why the FieldMsg isn't working because as others have mentioned, the syntax looks correct.
