01-26-2022 04:41 PM
We're currently looking for some best options to document the breach of an SLA for a given incident. For example, if an incident has breached SLA, we want to know the reason for the SLA BREACH before that incident could be closed. Does ServiceNow currently have OOTB functionality that supports this, OR what can we do in alternative please?
Multiple Versions
01-26-2022 06:36 PM
Exactly, it's a process question, rather than technical, but to your point, yes, you could create a solution where if a record is being set to resolved (closed happens out of box after 'x' number of days), and there was a breached resolution SLA definition associated to that record, then abort the save (via before business rule) IF...they haven't supplied an SLA Breach Reason, such as what you mentioned.
Out of box, there is no automatic solution for that. You'd have to review with your process manager, what you all want to capture. Do you want to supply a select box and on the "resolution information" tab, place it there and just have it full of selections? Or do you want it like a multi-text field where the technician needs to supply a reason?
It may not be a technical reason, right?
It could be a staffing issue? It could be a user error issue (where they didn't pause it appropriately)? It could be a vendor issue that you don't pause on and so that breached and it was an external entity issue?
Once you decide that and what you're wanting to resolve by reviewing these metrics, then you can set the technical plan in place to implement the solution. So for this, I'd recommend starting at the very end, then working backwards.
01-26-2022 06:55 PM
You're absolutely welcome!
If my reply above also helped guide you Correctly, please also mark as Correct.
Take care! 🙂
