Snowflake to Servicenow Integration
Poorva Bhawsar
Hi Team,
I need to pull data from snowflake into servicenow. What approach i need to follow to perform this integration? I already know that we can have this using jdbc connector but is there any other way to achieve this like rest api?
Poorva Bhawsar
12 REPLIES 12
And per your reply above...
If you've already reviewed certain options and have ruled some of them out, for whatever reason, then please add that to your post so that we're aware. We are unable to know what you have tried/haven't tried or prefer to use unless you tell us.
The request is 'I need to pull data from snowflake into servicenow...' The connector (from your link) helps to do the other way round (pull service-now data in snowflake - we are also doing that). But for a specific need I'd be interested in making queries to Snowflake using the SHF's SQL REST API.
architg0409
Use Zero Copy Connectors in Workflow Data Fabric available from Yokohama Patch 5 and Zurich Release.
Use below video for more info -
https://www.youtube.com/watch?v=sXCQ1ZK-3ec
60% of AI projects fail...not because of bad models, but because the data isn't ready. In this session, we walk through how ServiceNow's Workflow Data Fabric helps you unlock siloed data, connect to platforms like Snowflake and Databricks with Zero Copy Connectors, and power real-time AI Agents at
