Standard Change State Management
NilanjanB
Dear Experts,
I have standard changes which processes the decommission of the servers but the tasks that are created is controlled which means that the preceding task is dependent on the previous task.. but when the first task is closed after the change is moved to implement before the next task is opened, and the state changes to Review but the tasks have not even been populated and there are other tasks pending as well. It is an out of the box behaviour, but how to prevent that. Please help!!!
NilanjanB
I worked on the business rule it worked to held on the implement state
    var review_value = '0';
    // Add your code here
    var activeTask = new GlideRecord("change_task");
    activeTask.addQuery("change_request", current.sys_id);
    activeTask.addQuery("state", "NOT IN ", "3,4,7");
    activeTask.query();
    if (activeTask.hasNext()) {
        current.setAbortAction(true);
    var activeFlow = new GlideRecord("sys_flow_context");
    activeFlow.addQuery("source_record", current.sys_id);
    activeFlow.addQuery("state", "IN", "IN_PROGRESS,WAITING,QUEUED");
    activeFlow.query();
    if (activeFlow.hasNext()) {
    current.state = review_value;
})(current, previous);
I think BR is needed here mate
NilanjanB
    activeTask.query();
    activeFlow.query();
