Strange issue regarding Oracle Data Source and Mid Server
dante665
Hi all,
like the topic says. We have some Data Sources that use JDBC to connect via Mid Server to Oracle Databases. Sometimes the connection failes, with no particular reason. So we test loaded records manually. Sometimes the connection fails 5 times in a row, also with different Data Sources. A few minutes later after ONE connection is succesfull all other Data Sources get also an connection.
Anyone else with symptoms like this ?
Our instances: Geneva Patch 6 Hotfix 2
Mid Server Logfile entry: 08/11/16 13:12:10 (582) Worker-Standard:JDBCProbeError Worker completed: JDBCProbeError source: Did not get a response from the MID server time: 0:00:00.002
12 REPLIES 12
howellm
Kilo Expert
PRB665835   fixed in Helsinki patch 4 based on HI ticket I have open.
Hi Amit,
thanks for your work on that. But that seems not to be the problem that we have, if i filter the ecc queue like you mentioned there are no results. We also raised an HI Incident that is under investigation.
I will update this thread if we get an solution.
Many thank @ll of you !
Best, Henning
