Struggling with ITSM simulator lab:Create a catalog item
Lior Kaitel
im stuck on the last lab:
2. Create four mandatory variables to capture workshop date AND time, the workshop location, if a projector is required (yes/no) and the number of chairs required.
  a) The location field should reference locations in the system. [cmn_location]
  b) When asking about a projector, users should only be able to select Yes or No.
  c) Validate the user is entering in a number when asking for the number of chairs
i created all the questions as previewed in the task:
the locations Q is a reference, projector is a yes/no and the number of chairs are asking for a number only
yet i still get the error:
Does your question text match the requirement as shown in the instructions? Are each of the variable...
Lior Kaitel
i managed to find the issue
i updated the type to reference and to cmn_location(it was lookup select box)
johnpierce
The location item is what caused the error for me. I had Choice and Record reference and it did not like it... changing it to type = 'Reference' resolved the issue and it worked.
1. "Reference" was not one of the choices in the simulator drop-down, only 'choice' [which did not work]
2. Go to 'Maintain Catalog' and select 'Consulting Practice', go down to the catalog items and select 'Workshop Setup', then go down to 'Variables' and select the 'Workshop location' [if you are getting the error you will be clicking on 'Choice', now change the 'Type' to reference.
FernandoUrrutia
My bug report:
1- Catalog Builder automatically changed the category of my ITEM without warning. Please validate this.
2- It was not valid ("the Now Learning task validator") until I manually changed the "Location" variable in the catalog builder. I attached an image of the evidence of the correct form of the location field.
nicolasbreu
Make sure also your catalog item is in "Published" state and not still checked out in Draft.
