System property in ACL is not working
Bindhu1
I have created Create ACL  to give access to the 'New' button on the Related List for Catalog Tasks on the RITM form for specific group and catalog items.
Code works well when i give sys id of the catalog item directly but when i am storing the same sys id in system property and using in ACL script that time 'NEW' button wont be visible.
Here the code , Kindly help me how to achieve it from system property
//answer= (gs.getUser().isMemberOf('Administrative Business Center-Agents') &&
parent.cat_item=='7d2ded94db1b77002ed03df3399619e7');
// above line of code alone works good
var customSysId = gs.getProperty('testCat_item_sysid'); // Retrieve the 'sys_id' from the system property
gs.info("bindu AA " + customSysId); // log gives proper sys id
gs.info("bindu BB " + gs.getProperty('testCat_item_sysid'));
answer = (gs.getUser().isMemberOf('Administrative Business Center-Agents') && parent.cat_item == customSysId);
Expecting result;
Thanks in advance
@Bindhu1
answer = (gs.getUser().isMemberOf('Administrative Business Center-Agents') && parent.cat_item.getValue('sys_id').indexOf(customSysId) > -1);
17 REPLIES 17
@Bindhu1
did you check any space is there in your property value?
try to use trim()
gs.info("brunda AA " + customSysId); // log gives proper sys id
gs.info("brunda BB " + gs.getProperty('testCat_item_sysid'));
answer = (gs.getUser().isMemberOf('Administrative Business Center-Agents') && parent.cat_item.sys_id == customSysId.trim());
Hi @Ankur Bawiskar
I checked, No space is there in property value
@Bindhu1
are you sure the logged in user is member of that group?
Yes @Ankur Bawiskar because the script works fine for the same user when i keep sys_id of cat item directly .
answer= (gs.getUser().isMemberOf('Administrative Business Center-Agents') && parent.cat_item=='7d2ded94db1b77002ed03df3399619e7');
@Bindhu1
strange
