System property in ACL is not working
Bindhu1
I have created Create ACL  to give access to the 'New' button on the Related List for Catalog Tasks on the RITM form for specific group and catalog items.
Code works well when i give sys id of the catalog item directly but when i am storing the same sys id in system property and using in ACL script that time 'NEW' button wont be visible.
Here the code , Kindly help me how to achieve it from system property
//answer= (gs.getUser().isMemberOf('Administrative Business Center-Agents') &&
parent.cat_item=='7d2ded94db1b77002ed03df3399619e7');
// above line of code alone works good
var customSysId = gs.getProperty('testCat_item_sysid'); // Retrieve the 'sys_id' from the system property
gs.info("bindu AA " + customSysId); // log gives proper sys id
gs.info("bindu BB " + gs.getProperty('testCat_item_sysid'));
answer = (gs.getUser().isMemberOf('Administrative Business Center-Agents') && parent.cat_item == customSysId);
Expecting result;
Thanks in advance
@Bindhu1
answer = (gs.getUser().isMemberOf('Administrative Business Center-Agents') && parent.cat_item.getValue('sys_id').indexOf(customSysId) > -1);
17 REPLIES 17
Hi @Vishal Birajdar
Thanks for your reply , facing same issue with above code as well
Hi @Bindhu1
If possible can you show the System property may be screenshot.
Vishal Birajdar
ServiceNow Developer
- Socrates
Hi @Vishal Birajdar
here is he ss of system property
