To Create a Project charter template on click
arunram
Hi Everyone,
i have a requirement to create a project charter in the PM application on click of a button. i.e, the project charter form should be created from the values i have entered in the project form plus the values i have entered in the related lists. How can i achieve this ?
Thanks in advance
Pradeep Sharma
Hi Arun,
Not exactly what you are looking for but you can refer the below thread and adjust your code accordingly.
http://www.servicenowguru.com/system-ui/ui-actions-system-ui/copy-ui-action-change-requests/
I hope this helps
Hi Pradeep,
My Challenge is to put all the values   in a template and show the template on a button click
ranjanak
Hi @arunram ,
We are also looking for solution for the same requirement, did you able to achieve this. If yes, Kindly share your inputes.
