To get UserID in Onchange() Client Script
Options
01-30-2023 08:36 AM
I have a "request for" reference field in that field default value is logged in userid. So, If I select "exists"(its a checkbox) as No, then request for should be cleared. When I select back to "exists" as 'Yes' then UserID should be populated.
Can anyone help me to achieve this.
Thanks in advance
Options
01-30-2023 10:35 AM - edited 01-30-2023 10:36 AM
Hi @Ashok32
You can write an OnChange client script to achieve this and code as below
var exist = g_form.getValue('u_exists');
if(exist == false) {
g_form.clearValue("requested_for"); // You can also use g_form.setValue("requested_for"," ");
else{
g_form.setValue("requested_for", g_user.userID);
