To remove white spaces from a field
Poorva Bhawsar
Hi Community,
I have a BR using which i am removing the spaces from a field. First the data is getting being loaded via scheduled job. Once its loaded an after insert/update BR will work and it will remove the spaces from that field.
Here is the code, i thought it was working fine in background script but now it didnt removed spaces from 2 records.
var record = new GlideRecord('xyz');
    record.query();
    while (record.next()) {
        record.abc = record.abc.toString().replace('ABCD', '');
        record.abc = record.abc.toString().replace(/ /g, '');
        record.setWorkflow(false); //Do not run business rules
        record.autoSysFields(false); //Do not update system fields
        record.update();
Let me know is there any change required in the code and why it didnt removed spaces for 2 records.
@Poorva Bhawsar
okay got it
then do this and it will replace 1 or more whitespaces
record.abc = record.abc.toString().replace(/\s+/g, '');
Runjay Patel
Hi @Poorva Bhawsar ,
Try using below code.
record.query();
    if (record.abc) { // Ensure the field is not null
        var updatedValue = record.abc.toString()
            .replace(/ABCD/gi, '') // Case-insensitive removal of 'ABCD'
            .replace(/ /g, '');    // Remove all spaces
        // Update only if there's a change to prevent redundant saves
        if (record.abc.toString() !== updatedValue) {
            record.abc = updatedValue;
            record.setWorkflow(false); // Skip business rules
            record.autoSysFields(false); // Skip system field updates
            record.update();
In this video i have explained about Web service integration in ServiceNow like how it works, how we can configure it, what are the prerequisite and many more. I have covered below topics in this video. 1. understand Web Service. Like when and how we will use it. 2. Talked about Inbound and ...
