Track Assignment Group Changes with Metric Definition
09-16-2025 11:10 AM
By default, ServiceNow provides the Assignment Group metric definition to track the current assignment group value of a record. However, this out-of-the-box (OOB) metric only records the present value and does not capture both the old and new values when the assignment group changes.
To support improved auditing and reporting, we can configure a custom metric definition along with an additional field on the Metric Instance table. This enhancement allows us to track both the previous and current assignment group values whenever the field changes on Incident table and can also be used for reporting to know the duration of different groups for specific record (or other tables, if required).
Procedure
Step 1: Create a field for Old Value
- Navigate to System Definition > Tables.
- Open the Metric Instance [metric_instance] table.
- Create a new field:
- Column Label: Old Value
- Column Name: u_old_value
- Type: String
This field will store the previous assignment group value.
Step 2: Create a Metric Definition
- Navigate to Metric Definitions (metric_definition.list).
- Click New and provide the following details:
- Name: Assignment Group Changes
- Applies to Table: Incident
- Field: assignment_group
- Type: Field Value Duration
- Copy the Sys ID of the metric definition.
Step 3: Store the Metric Definition Sys ID in a Property
- Navigate to System Properties > All Properties.
- Create a new property:
- Name: assignment.group.metric.sys_id
- Type: String
- Value: (Paste the Sys ID from Step 2)
- Save the property.
Step 4: Create a Business Rule on the Incident Table
- Navigate to System Definition > Business Rules.
- Name: Track Assignment Group Changes
- Table: Incident
- When: Before
- Update: Checked
- Condition: current.assignment_group.changes()
- In the Advanced section, add the following script:
insertMetrics();
function insertMetrics() {
var mi = new GlideRecord('metric_instance');
var metricSysID = gs.getProperty("assignment.group.metric.sys_id");
mi.initialize();
mi.definition = metricSysID;
mi.value = current.assignment_group.getDisplayValue();
mi.u_old_value = previous.assignment_group.getDisplayValue();
mi.start = previous.sys_updated_on;
mi.end = gs.nowDateTime();
mi.duration = gs.dateDiff(mi.start, mi.end);
mi.id = current.sys_id;
mi.table = current.getTableName();
mi.field = "assignment_group";
mi.field_value = current.assignment_group;
mi.calculation_complete = true;
mi.insert();
})(current, previous);
Output :
When the Assignment Group on an Incident record is changed, a new Metric Instance record is created using custom Metric Definition we created showing the old group, new group, start time, end time, and duration. These records can then be used in reports to see how long each Incident stayed with different groups.
- 4,723 Views
10-05-2025 05:11 PM - edited 10-06-2025 01:37 AM
Hi @Praveena Patel, @Ankur Bawiskar
I have created a Business Rule and Metric Definition to track Assignment Group changes on the Incident table - it now creates a Metric Instance record with old and new values whenever the group changes.
My question is:
How can I capture the historical Assignment Group changes for existing incidents that occurred before this Business Rule was implemented?
Is there a background script/scheduled job that I can run to populate Metric Instances for those past records?
10-13-2025 01:20 AM
Hi @surajchacherkar,
I understand your concern regarding tracking historical Assignment Group changes. However, the Metric Definition will only start capturing data from the point they were created and activated. Unfortunately, it’s not possible to retroactively generate Metric Instances for Assignment Group changes that occurred before the implementation, as those historical changes were not recorded at the time.
From this point onward, all new Assignment Group changes will be tracked automatically through the configured Metric Definition and Business Rule.
Please mark this response as an Accepted Solution and/or Helpful if it resolves your issue.
01-29-2026 09:13 AM
Can you explain why there is a blank/duplicate metric record below your highlighted one?
08-28-2026 05:00 AM
I'd assume this was before the incident was assigned to an assignment (or that the assignment group was removed)
