transform script is not working
Could you please help me with the transform map script so that it works properly
answer = (function transformEntry(source) {
    var owners = source.u_owner_name || '';
    if (!owners) {
        gs.info('TM Owners empty');
        return '';
    var arr = owners.split(',');
    gs.info('TM Owners tokens=' + arr.length);
    for (var i = 0; i < arr.length; i++) {
        var userVal = (arr[i] || '').trim();
        if (!userVal) continue;
        var userGR = new GlideRecord('sys_user');
        userGR.addQuery('user_name', userVal);
        userGR.setLimit(1);
        userGR.query();
        if (userGR.next()) {
            gs.info('TM Matched user_name=' + userVal + ' -> ' + userGR.getDisplayValue());
            return userGR.name;
            gs.info('TM No match for user_name=' + userVal);
    })(source);
@Community Alums Could you please try the following.
    var owners = source.u_owner_name+'' || ' ';
    if (!owners) {
        return '';
        userGR.setLimit(1);
        userGR.query();
            return userGR.name.toString();
    })(source);
Here I have replaced the line return userGR.name; with return userGR.name.toString(); ideally the string conversion should force the value to be retained.
Hope this helps.
Sandeep Rajput
@Community Alums Tried running your script in background scripts and it runs just fine. Any specific issues you are facing with this script?
@Sandeep Rajput      this script not working when i am putting in the source transform map script, it is giving undefined return
    var owners = source.u_owner_name || ' ';
    if (!owners) {
        return '';
        userGR.setLimit(1);
        userGR.query();
            return userGR.name;
        } else {
    })(source);
    if (!owners) {
        return '';
        userGR.setLimit(1);
        userGR.query();
    })(source);
Hope this helps.
