Unable to Order a catalog item in portal using ATF
04-17-2020 01:01 AM
When i try to order a catalog item using "Order a catalog item(sp)" it is failing with the summary as "FAILURE: Validations failed. Failed to Order Item." These are the steps that i followed, and also once I open the catalog item in the portal page, I am unable to find some fields even though i have defined those variables
Can someone please help me find a solution to this.
Supritha F
04-17-2020 03:49 AM
Hi Swapnil,
the same details have been shared 3hours ago in my previous comment; it's just copy paste of the same HI article. Please avoid this.
04-17-2020 05:06 AM
Hi Ankur,
Actually i am not seen your post. I just found this so I reply this here.
12-17-2024 11:43 PM
Forums moderation is for moderators only.
04-17-2020 04:16 AM
Hi Swapnil,
Thanks for the suggestions.
Supritha
04-17-2020 04:14 AM
Hi Ankur,
Yes the 2nd step is not required i just added it to check the portal page, but then even without step 2 I am not able to order the catalog item.
I did set the system property glide.sc.sp.twostep to true which i suppose is responsible for the order confirmation pop-up and also increased the timeout but still seem to have the same issue.I can see that the browser does not submit the form to server. One more notable thing is that even after giving a timeout up-to 35s I do not see any lag before moving to the next step, could this be a reason?
Supritha
