Unable to Order a catalog item in portal using ATF
04-17-2020 01:01 AM
When i try to order a catalog item using "Order a catalog item(sp)" it is failing with the summary as "FAILURE: Validations failed. Failed to Order Item." These are the steps that i followed, and also once I open the catalog item in the portal page, I am unable to find some fields even though i have defined those variables
Can someone please help me find a solution to this.
Supritha F
04-17-2020 04:22 AM
Hi Supritha,
at which step it fails? Is it on open a catalog item (sp)
04-17-2020 04:34 AM
Hi Ankur,
No its failing in the "order a catalog item(sp)" step.Well I can also see an order confirmation pop-up but then it fails as the final status.
Supritha F
04-17-2020 04:52 AM
can you share test screenshot of that step after it ran; order a catalog item (sp)
04-17-2020 05:03 AM
04-17-2020 07:14 AM
So at Order a Catalog Item (SP) it is failing
Is this for your personal instance?
Your instance is on NewYork which patch? in New York Patch 3 it is fixed
